2022 IS 350 REAR Turning Signal Bulb
2nd gear
Does anybody know the exact bulb size/number for the 2022 IS 350 Turning Signal. I want to replace that amber look for a LED look but I do not know the rear turning signal bulb. I think it is 7440 or 7443 but I am not sure I wanted a second opinion on it.
Pick your poison as both will work. The difference is the 7443 is a dual filament bulb and will usually costs more.
Side note: Make sure you pick up a bulb with a built in resistor (like from SiriusLED) to avoid the "hyperflash" problem that occurs from switching to LEDs..... unless you'd rather just wire your own resistors in-line.
LS430inDE.
05-27-19 10:32 PM
