2016 IS350 driver side O2 sensor
My engine check light came on so I pulled out my scanner which picked up error code P013C. The error code referred to O2 sensor bank 2 sensor 2. I would like to replace both the right and left sensor. The passenger side looks straight forward. I pulled the carpet back on the drivers side and I found a connector but there was nothing connected to it. Assuming I found the correct plug I am baffled. I could only pull the carpet back mid way down the center console and I could not find a loose cable. Attached is a pic of the connector to the right of the gas pedal.
I took a couple of pictures of the drivers side upper O2 sensor. According the OEM part 89467-53070 it should only be 10 inches long with a connector. In my pictures there is no connector near the sensor. Does anyone have experience replacing this sensor?
I should have mentioned mine is AWD so pic B. Now that makes sense why the connector i found is not used. Is that an image under the seat? Any chance you have the part# of the sensor? Everything I have found shows a 10 inch cable. That looks more like 24 inch.
For the drivers side I purchased the Denso 234-4945 oxygen sensor. The connector is under the seat so I did remove the seat. Removing the seat was not an issue.I think there are 3 wire loom connectors underneath, the 4 floor bolts and a bolt for the seat belt.
