Beware of Paintless Dent Repair on Door Dent!Door Panel Damage!
9th Gear
I have a tiny door dent on my driver door and had a PDR done today. After the repair I noticed that the black plastic trim on the door panel is bent inward and upward. The plastic trim I am referring to here is the most upper portion of the door panel where it meets the window. Apparently, PDR will need to gain access to the back side of your door. The way they do it is to put a wedge in between the door panel and the door skin to force it open. I can tell that wedge is very forceful. The door skin is all good because it's metal, but the door panel is just plastic, so it bends (or call it permanently deform). Sharing it here hoping this will help folks decide if PDR is necessary. You may fix a door dent but you can easily bend your door panel, which cost 300-500$ to buy a used one.
I wonder if that is always the case, or if that PDR shop was just careless.
I hope the PDR shop would pay for damages they caused. I guess in this case, they should have physically (and properly) took off the whole door panel itself.
9th Gear
I guess it all depends on how hard they wedge your door panel. In my case, it was way too hard. Unfortunately, the shop won't pay me for the damage, I accepted the risk before the work was commenced. I hope that in the future, when you guys do PDR, you should keep a close eye on the progress and call it off if you see any potential of damaging your door trim. I will attach a pic or two later today regarding the damage I got. It's not horrible but it's visible especially when sunlight shines at it.
I have had PDR on various cars done multiple times without issue. Looks like they accessed the dent through the top and didn't use anything to support the tool. Pretty amateur hour. If they did end up pulling the door panel, it is super easy to fix, it may not be aligned in the channel properly.
9th Gear
That hurts, imo if i were you, I would take it back and ask them to form it back. As the panel is plastic, I have seen some shops able to heat-form some bent plastic back to original form. That door panel is designed to withstand UV and sun's rays, it can take the heat, so to speak and won't break so easily. At the very least, take it back and see what they say.
And why they didn’t just remove the door card like a normal person is beyond me, there’s zero reason to pry it like that.
2022IS300 (06-26-23)
ArcholeLS4
09-14-22 12:58 PM
