2023 IS350 transmission hick-up....
#32
#33
any updates or resolutions ???
My is350 had a weird shift this morning when I first started driving . Car was COLD. 3500 Miles and I m not sure what I even felt. thought it slipped at about 25 MPH coming thru a turn but only happened once and I was caught off guard cause it always shifted great.
I was hardly on the gas and the road were dry.
When I looked down I thought I saw 5th gear. regular mode.
#34
Right, between gears the RPMs jump a bit. This seems to happen a lot for me between 2nd and 3rd gear. In my IS 350, this phenomenon was a regular occurrence in the winter, and it seems to be similar for the 500 now. After driving for a minute or two, everything settles down to normal. It's just that initial pulling out onto a street when I observe tihs.
Fizzboy7 (11-30-23)
#35
Need to revive this thread.
Had the "dead" gas pedal again yesterday. But this time it was very distinct what took place. Was in normal drive mode, traffic jammed in front of me, and I came to a very fast stop. The car in front of me was a few feet ahead of my bumper. Then when I went to accelerate on the green, gas pedal was dead. It then slowly gained it's normal speed. So, now it's got me thinking, did I also come to a sudden stop the first three times it happened? I think at least on two of them, yes. Or one was a downhill and I had to apply the brakes harder than normal. But all times there was a car in front of me that was closer than the usual space I leave at a stop. And all of the times there were no warning lights or buzzers that went off.
So maybe the car goes into some stupid safety mode after it thinks I cut it too close ??? But what could possibly be the saving grace for not allowing someone to move away from a stop after a fast stop already occurred? Trying to make sense of this, and/or perhaps something is still not right with the computer or sensors to allow a dead gas pedal. Total time it's happened in one year is four. Seems like a hazard if one cannot pull away from a green light and I've never heard of any car doing this.
Thoughts?
Thoughts?
#36
Thoughts?
Thoughts?
#37
#38
#40
The description sounds a lot like what has happened to me a few times when I step on the gas but still have the brake pedal partially depressed (try it and see if that matches your experience after hard braking). Wonder if maybe the brake system hasn’t fully released for some reason, and triggers the lack of throttle response you’ve seen.
MWIS350
05-28-15 02:56 PM
