Engine shuts off when driving
4th Gear
Hey guys,
I need some advice, I recently bought a 2014 Is250 and when I did the test drive my mechanic said that it may need a spark plug change based on how it felt. The previous owner stated that he hadn't changed plugs in a good while as well. but it wasn't that bad. I got the car and I could feel the delay when it was moving off, but once it picked up speed it was good to go. However, one night I was at a stop light, and when I stepped into the gas to move off. it stalled, and a message came up saying, "Engine has stopped, place the gear in park and start the engine" Once I did that it drove off, and that happened 3 times. Has this even happened to anyone else? and do you think that the weak/bad spark plugs are the culprit?
Hey guys,
250's lack port injection, so carbon buildup is inevitable. If your engine has higher milage, this could likely be the culprit. Pull your plugs and take a look. Boroscope the combustion chamber and take a look at the top of the pistons, the valves, the back of the valves/valve stems.
4th Gear
How many miles are on your car?
