Ignition coil bolt snapped in half
Old 12-22-23 | 02:15 PM
axg200t's Avatar
axg200t
10th Gear
Default Ignition coil bolt snapped in half
Hello,
I was replacing the spark plugs on my 2016 Toyota 200t. After I replaced them and tightened the ignition coil bolt, it snapped in half. I've attached an image for reference. Can you suggest a solution? Is this an easy fix? Is it safe to drive the car temporarily?
Old 12-22-23 | 10:29 PM
TonyN's Avatar
TonyN
I would not drive it.
bolt extractor kit or weld on a nut and remove it. Seems like a over torque bolt, hopefully you didn't mess up the tread.
axg200t (12-27-23)
Old 12-27-23 | 08:07 PM
axg200t's Avatar
axg200t
10th Gear
Thank you, i was able to pull it out using bolt extractor
HawkeyeIS
12-13-22 11:04 PM
HawkeyeIS
Maintenance
12-10-22 09:17 AM
Regeana1
03-26-20 06:12 AM
Bulls430
03-21-19 08:44 AM
cooper123
12-05-16 08:54 PM
