Which LED Front and Rear Turn Signal Bulbs?
Old 12-23-23 | 11:39 PM
Lex_Giorgio's Avatar
Lex_Giorgio
Default Which LED Front and Rear Turn Signal Bulbs?
Anyone here swapped the turn signal for an LED one? If so, which one did you use?
It's for a 2017 IS, looking for bulbs with built in resistors.
Thanks in advance!
Old 12-24-23 | 05:04 AM
we1rdoo's Avatar
we1rdoo
Thanks in advance!
actually you can easily find trinocular front headlights(which have led turn signals by default) in Japan, that’s what I did in my 2021 IS, from manufacturer it came out with standard single led headlight, I bought OEM trinocular headlights in Japan with cheaper price than dealership, unfortunately I could not found headlight computers in Japan on that time because new model IS was just introduced, but I ordered computers for trinocular headlights from Lexus dealership, and dealership helped me as well to install them, Japan headlights works perfectly on my car, one thing is that I also installed height sensor on my car which is the same for all 2013+ models, so you can easily find it on junkyard or someone who parts out the car, installing necessary software and you are good to go.
for example, this one comes even with computer:
https:/www.fromjapan.co.jp/japan/en/auction/yahoo/input/q1118341032/
or you can take a look at the list of the headlights:
https://www.fromjapan.co.jp/japan/en...52;ト/-/
at the beginning, Lexus dealership told me that they would not be able to make them work, but I insisted them to try and it worked.
Old 12-25-23 | 09:57 AM
Lex_Giorgio
Thanks for the info!!
I wasn't planning on swapping the entire headlights (not yet at least), just looking to change the bulb to an LED for now.
zanewyn
NX - 2nd Gen (2022-current)
24
03-11-24 04:33 PM
798pof
RX - 4th Gen (2016-2022)
18
05-09-23 10:43 AM
coyo
04-13-22 12:41 PM
