id probably just tap into the fuse panel above your left foot when you sitting in the driver seat. Find a constant and accessory, use a bolt under the dash with some wire for a ground.. What are you trying to do?
I'm going to install power folding mirrors eventually and I wanted to know where I could source the constant power, an accessory wire and a ground in order to make them work.
