Something about transmission I guess
Old 01-07-24 | 03:22 PM
steve0024's Avatar
steve0024
4th Gear
Default Something about transmission I guess
is350 2022
I moved the car out of my storage unit this morning when it was about 5 degrees Celsius (41 degrees Fahrenheit). After starting the car and shifting it into reverse, I didn't feel it rolling. So, I gave it a little bit of gas, and the revs went up to 2500 to 3000 RPM, and it started reversing at a slow speed. I then put it in neutral, waited for a few seconds, and shifted it into drive, but it still didn't roll forward without touching gas paddle. Finally, I shifted it into park and then shifted it again, and everything seemed to go back to normal. After that, I checked with the ECU scanner, but no code appeared. Does anyone know if there's something wrong or if something caused this issue?
Old 01-08-24 | 04:05 AM
BobbyGee's Avatar
BobbyGee
How long after starting it you put it in reverse? Did you wait for the engine and oil transmission to warm up a bit?
Also, how many Km or miles does the car have?
steve0024 (01-09-24)
Old 01-08-24 | 05:11 AM
cerbois's Avatar
cerbois
Low fluid is all I can think of with such a new car. I posted a while ago on my 23 IS, when the weather first got cold I had a weird shift the first few minutes.
Have the level checked by dealer if you can.
Old 01-08-24 | 11:36 AM
arentz07's Avatar
arentz07
Yeah it's still under factory warranty at this point; there's no reason not to go to the dealer other than inconvenience. I owned a 2021 IS 350 for almost two years and never saw an issue like that.
Old 01-09-24 | 04:13 AM
steve0024's Avatar
steve0024
4th Gear
I check the level at the dealer they don’t see anything wrong with it. My friend suggested me to do the fluid flushing. And switch from oem fluid to motul.
Old 01-09-24 | 04:14 AM
steve0024's Avatar
steve0024
4th Gear
had it start for about 2 minutes
Old 01-09-24 | 04:18 AM
steve0024's Avatar
steve0024
4th Gear
Dealership can’t find anything wrong and they think it’s a matter of chance the gear did fully engage with in low temperatures. The mechanic at dealer told me that transmission fluid does warm up as engine oil. And especially after long period of low temperature parking they are recommending give it a good warning up.
situman
02-05-16 08:40 AM
static
ES - 5th Gen (2007-2012)
12
10-24-15 06:45 AM
chi123
10-02-12 12:25 PM
StpdSavant
07-24-11 10:13 PM
h4vok
18
09-09-09 07:20 PM
