Swapping Window Control Switches on 2016 IS 300
6th Gear
Can anyone tell me if the Window Control Switch Assembly from a 2016 IS 200T F-Sport can be used on a 2016 IS 300 base model? There are multiple options for upgrading the interior trim pieces on an F-Sport model but none for the lowly base model (aside from cheap eBay stickers vs more sophisticated and upscale offerings for F-Sport models from Elvin Wong, RR Racing, and others)!
Can anyone tell me if the Window Control Switch Assembly from a 2016 IS 200T F-Sport can be used on a 2016 IS 300 base model? There are multiple options for upgrading the interior trim pieces on an F-Sport model but none for the lowly base model (aside from ebay stickers vs upscale offerings from Elvin Wong and others)!
If it's yellow, you have to swap it with another yellow one.
The front passenger door and both rear doors use the same switch panel, it's only the driver switch panel that's different.
Yellow = IS with memory seats
This is back of the memory seat one:
wylie7 (01-31-24)
wylie7 (01-31-24)
6th Gear
Yes, I'm talking about replacing both the switch assemblies and the trim covers. It is an entirely different switch assembly on the base model compared to same-year f-sport models.
The passenger and rear doors uses the same switch regardless of the memory seat function.
wylie7 (01-31-24)
Lex_Giorgio (01-31-24)
