Preventive maintenance
Old 03-04-24 | 02:54 PM
mhubbss33's Avatar
mhubbss33
Default Preventive maintenance
Hi, I have a 2018 IS350 F-Sport RWD with 61,500 miles on it. I replaced spark plugs, Transmission fluid and brake fluid and I am doing Diff fluid soon as well as coolant. I was wondering if there is anything I should look for wear wise, I was thinking about upgrading the LCA bushings to RCF ones. But is there anything else I should inspect and replace that are common issues that people with higher mileage IS’ have had? Thank you
Old 03-04-24 | 09:13 PM
NYIS300awdFS's Avatar
NYIS300awdFS
Clean the throttle body, clean maf, replace pcv, replace cabin filter, replace air intake filter, dump a can of Seafoam in the tank when you fill up.
mhubbss33 (03-05-24)
Old 03-05-24 | 09:30 AM
JNP1227's Avatar
JNP1227
Just keep up with regular maintenance on the car and use good quality oil.
For reference my 3IS has 176k on it.
Old 03-05-24 | 10:26 AM
mhubbss33's Avatar
mhubbss33
Will do! Thank you
Old 03-06-24 | 05:27 AM
BillUK's Avatar
BillUK
If I was intending to keep a car for a while then, apart from the usual maintenance items, I'd also apply some rustproofing to the underside, wheel wells, and sills (rocker panels to you folks). This could be a simply spray over with something like ACF-50 or Fluid Film, which would take less than an hour, up to applying a wax type treatment (I use Dynax products) to all the surfaces and cavities.
Old 03-06-24 | 07:33 AM
NYIS300awdFS
Default Rust proofing
I’m actually going to be rust proofing my car, ordered everything I need to do wool wax. Ordered a few quarts of the material and a couple of their spray wands. I’m in it for the long run. I kept my Subarus from rusting with Fluid Film cans but I’m stepping it up to the next level.
iamroddy
Build Threads
30
04-03-24 05:49 AM
Realzking1
Performance
09-27-20 03:47 PM
Matsui
GX - 1st Gen (2003-2009)
09-19-14 06:50 AM
LSorBS
05-17-10 04:09 AM
Gekko
Maintenance
03-03-03 03:50 PM
