Battery tender POSITIVE post adapter
Is there a safe positive post adapter to provide quick connect-disconnect to a battery tender.
Like something that is permanent mount to the bat terminal. Maybe a simple #10 wire to
the connector post to catch the alligator clamp.
I also use that type of wire extension so that while I can't even reach my battery when in the garage, the wire connector is near the front of the engine across from the battery and right next to my charger on the wall. In fact, if you wanted to run the wire through the grill, you wouldn't even have to open the hood.
Did that after finding her hood frozen shut one morning and the battery was flat.
