2014 IS250 lower control arm bushings
Old 06-20-24 | 02:52 PM
Poor3IS's Avatar
Poor3IS
5th Gear
Default 2014 IS250 lower control arm bushings
I am new here and I cant seem to find an answer to my question on other threads. I have a 2014 IS250 F-sport and I would like to replace the front LCA bushings. What bushings can I use besides the RR or Figs since I am not using my car on a track?
The main purpose is to slow down AND/OR completely stop front inner tire wear. Trying to keep the budget reasonable and will be doing the job myself. Thank you in advance.
Old 06-20-24 | 04:22 PM
kj07xk's Avatar
kj07xk
Read this thread, your other option is the GSF/RCF bushings, although they may or may not prevent the wear, depends on your driving style. I went with the Figs and installed them myself.
Inner tire wear
Old 06-20-24 | 04:25 PM
Poor3IS's Avatar
Poor3IS
5th Gear
Thank you for the reply. I drive like a grandpa. Ill try the RC-F ones and pray. Thank you for your help. Random question. Would it be easier to use a jack to life the front of the car or drive it up onto ramps? IDK is pressure on the wheels will make the job harder or not.
Old 06-20-24 | 07:14 PM
kj07xk's Avatar
kj07xk
Need to jack it up, the suspension needs to be unweighted during the remove and install (although you need to reweight the suspension for doing the final torque (use another jack to lift the suspension)).
There are several YouTube videos out there on how to do it (previous gen cars, but same process), here’s a short example:
Lower control arm bushing replacement
smitty2919
Suspension and Brakes
10-04-24 07:29 AM
dosnglenn
IS F (2008-2014)
20
11-30-23 11:03 PM
B777Pilot
02-20-22 09:58 AM
Snowrydr01
09-26-16 03:05 PM
nadude98
GS - 1st Gen (1993-1997)
12-23-13 10:07 AM
