3rd Generation - Lexus IS 250/300h/350 Info & Specs
3rd Generation - IS
IS - Intelligent Sedan
Chief Engineer Junichi Furiyama (Past Projects: 2nd Gen IS F SPORT & 2nd Gen IS Convertible)
Models:
GSE30 - IS 250 - 2.5L V6 4GR-FSE (RWD) 6AT
GSE35 - IS 250 - 2.5L V6 4GR-FSE (AWD) 6AT
GSE31 - IS 350 - 3.5L V6 2GR-FSE (RWD) 8AT
GSE36 - IS 350 -3.5L V6 2GR-FSE (AWD) 6AT
AVE30 - IS 300h - 2.5L 4cyl 2AR-FSE (RWD) CVT *Not available in North America*
*IS F & IS Convertible are carryover for 2014.
Drive Layout:
Front Engine - Rear Drive
Front Engine - All Wheel Drive
Preliminary Specifications:
USA (IS 300h Not Available in North America):
Japan
Australia
Tires (IS 350F SPORT & IS 300h):
Bridgestone Potenza S001
Front: 225/40R18
Rear: 255/35R18
2IS IS350 dimensions:
Length - 4580 mm (85mm shorter than 3IS)
Width - 1800 mm (10mm shorter than 3IS)
Height - 1415 mm (15mm shorter than 3IS)
Wheelbase - 2730mm (70mm shorter than 3IS)
Definately a few inches longer than the 2IS to increase the backseat space, other dimensions pretty negligible. Still would like to know the weight.
Compare that with the 4th gen GS that donated the chassis for the new 3rd gen IS :
Length : 4580 (2IS) 4665 (3IS) 4850 (4GS)
Width : 1800 (2IS) 1810 (3IS) 1840 (4GS)
Height : 1415 (2IS) 1430 (3IS) 1455 (4GS)
Wheelbase : 2730 (2IS) 2800 (3IS) 2850 (4GS)
Included for interest the Infiniti Q50 dimensions :
Length : 4783
Width : 1824
Height : 1443
Wheelbase : 2850
Length : 4783
Width : 1824
Height : 1443
Wheelbase : 2850
It should still be lighter than 3GS though.
Jeff
usage of newer techniques such as high tensile steel usage will help for sure, but otherwise you might be right... it might be 3600 for instance too. I know that if it was lighter, it would be advertised as lighter... but since the wheelbase grew by 3".... Also new technology is usually heavier too... so whatever they lost by using high tensile steel, they probably gained back and more by making the car a bit bigger and giving it more tech and safety.
I know everybody targets the 3 series when designing and developing this class of cars but those demension specs are pretty much an exact close of the new 3 series. I'm glad they added some major length to the car because those back seats were way too small.
