I wanna say yeah. Pretty sure the lugs that came with them were. I’m pulling wheels to rotate and clean next week. I’ll you know for sure.
When this wheel was on the Lexus is350, it was using the lug bolt instead of the lug nut. If you have a chance to take off your wheel, can you take a picture of the ug you are using?
Follow me on insta
@Dev_3is Modellista Kit with JDM Triple Beams and Painted Grille in Gloss Black 2013-2017 LexusLS460 Mirror Shell Retrofit Swap 19" Reverse Lip Low Disc Diamond Cut Ordens Tiple Beams with Custom F-Sport Fog lights painted in Gloss Black Rowen Trunk + JDM Tail Lights + OEM Diffuser Painted Gloss Black with Artisan Style Valance in Gloss Black
It is a conical Lug.
Ran into an issue with the wheels not fitting with a spacer tonight though. The pockets on the wheels are really shallow compared to the f sport wheels. Trying to avoid cutting the studs at the moment as the f sport wheels will go back on once powdered, these will be the winter set and they don’t look horrible as they are.
