Tires recommendation.
I bought these wheels for my 07 IS250 with lexus offset. The fronts are 19x8.5, rears are 19x9.5. I was thinking 245-35-19's and 275-35-19's in the rear. Can i get away with 40 series sidewall? What is your recommendation on tire sizes? I dont like the stretch look either.
http://www.tirerack.com/wheels/Wheel...cut&tab=wheels
Check the specs on the tire on tirerack for the overall diameter of the tire itself...See how close you come to the over all diameter of your current 275/35 rear tire...if its a touch under like .2 or .1 or over by .2 or .1 then you should be fine..
I doubt it given the current specs tht I know....running a 40 series with a 275 (if you can find one) will more than likely rub
terryakhan
Suspension and Brakes
04-03-15 07:27 PM
