Peddle Dance On 14' 350 F-Sport
Old 07-24-13, 06:32 PM
micel
micel's Avatar
Default Peddle Dance On 14' 350 F-Sport
I did peddle dance on new is350 and got some nice 2 gear rubber.The salesman said "oh you do not need to do that with the dial and trc switch".We compared the two and there was a big difference in off line acceleration .I have not found any info on rear differential ratios although I imagine the transmission ratios to be the same in the is-350 as Lexus did not change them in the LS and IS-f .My '06 is350 feels considerably faster through the first 4 gears or about 110mph.My only mod is a k&n drop in filter.Totally off topic but I also found the new 350 to have less leg room for driver.Any other opinions on this out there?
Old 07-24-13, 07:42 PM
John510
John510's Avatar
What is a peddle dance?
Old 07-24-13, 10:31 PM
chris2k5
chris2k5's Avatar
I was wondering the same.
Is it the salsa type of dance or the clubbing type?
Old 07-25-13, 04:34 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
(LOL, I almost had the same reaction)
Has to do with disabling Traction Control and ABS. The question is, if these can be disabled "with the dial and trc switch" as opposed to doing the dance :
Old 07-25-13, 04:45 PM
micel
micel's Avatar
i believe only lexus of japan knows the true extent of what and how far or long(duration) it disables built in safety gizmos.I do know it works on all Toyota vehicles I have tried it on.Some safety things like the rev- limiter is not affected at all.From my experience if you can get traction ,it makes a world of difference in acceleration
Old 07-25-13, 05:01 PM
spwolf
spwolf's Avatar
You can find 2014 specs here:
http://pressroom.lexus.com/releases/...duct+specs.htm
Old 07-25-13, 05:38 PM
saferisk
saferisk's Avatar
Will try this weekend and report back
Old 07-26-13, 07:57 AM
mrraider
mrraider's Avatar
The pedal dance in the 2IS was only necessary ofr the first model year. From 2008 onwards, holding down the Traction control button would turn of VSC also. It would re-engage above 40km/h I believe.
Old 07-26-13, 08:22 AM
4TehNguyen
4TehNguyen's Avatar
its a "cheat code" to disable the VSC on some of the early 2IS
Old 07-26-13, 04:46 PM
micel
micel's Avatar
The trc switch only partly disables the traction control on all is's.Lexus did change '07 and newer is's so the light stayed on,but it still cut power to wheels.
J3ffrey
12-04-15 08:21 PM
SilvaIS350
04-07-15 01:34 AM
mark168
08-10-14 08:03 AM
bshaw777
07-16-13 06:25 AM
00LexusGS3
03-09-11 08:43 PM
Quick Reply: Peddle Dance On 14' 350 F-Sport
