Can any 3IS F-Sport owners verify if the e-LSD (brake-based LSD) stays active when you turn VSC off (Holding the Trac button for 3 seconds)? On the 2IS, the eLSD will be active only when the VDIM is fully engaged but if you disable VSC, you lose the eLSD function.
