Interesting Little Details Discoveries Thread (Good or Bad)
#556
#557
The radio sorts the file like a computer and put the first digit and so on numerically. So for you to play it in order you will have to name your mp3s starting with 01 02 03 ... 10. It all depends on how many files you have. That is why I decided to get an iPhone 6 and use the playlist to stream through Bluetooth ..
Not sure if this is posted but a bit angry. Because of all the IPOD error issues (I have IS350 Fsport (2015)), I went and got a 128g usb, which is working perfectly except for 1 big problem. I have all the mp3 tags correctly labeled showing the track number etc. But when you play a folder, it never plays in the correct order. It starts with track 1, then track 10, then 2, then 20 etc.. It's ignoring the track number altogether and trying to do it by name. For example I have it like this: Is there any fix? Really frustrated with the lack of audio fixes with many problems that ruin the travel with music.
1. Firsttrackname
2. Secondtrackname
etc
1. Firsttrackname
2. Secondtrackname
etc
So to bypass that problem, you need this little tool that I use with my 64GB usb key. It's called DriveSort and allows you to sort however you want. Even sort your files in a "playlist mode" so you can play your favorite tracks and what not, first. Other tools with the same purpose also exist but that's the one I use.
http://www.anerty.net/software/file/DriveSort.php
#559
Anyone know if the backup camera will start beeping once you get too close to another car or structure? I kind of miss that in my old Audi and not sure if it's on the 2015 Lexus IS 350 w/Navigation package. It hasn't yet beeped and I don't know if that's because I haven't come close enough yet or it just doesn't beep at all.
#561
Mine is a '14 that has BSM. And whenever I parallel park and backup next to the curb, it will beep. Sometimes, there's a car behind me, and sometimes there isn't and it's just the curb. I have noticed that it will beep if it detects inanimate objects are too close. It's even beeped when it senses a pole behind me.
