How to: Changing Lane Change Flasher from 3 to 5 or 7
Old 03-19-14, 12:42 PM
  #46
carderoni
carderoni's Avatar
Sorry for the stupid questions, but could anybody clarify the below for me?
Originally Posted by doodlebug
3.) While holding the wiper switch in the full up position, turn the IG on. (two presses of the start/stop switch)
Is this step done with or without holding down the brake pedal?
5.) Move the wiper switch down one "click" or "notch", hold for 5 seconds
7.) Move the wiper switch down one "click" or "notch". hold for 5 seconds (same position as step 5)
Is this one click/notch from the complete up/off position, or one click/notch from the rest position?
Old 03-19-14, 12:51 PM
  #47
yardie876
yardie876's Avatar
Look at this video:
Old 03-19-14, 02:01 PM
  #48
sc00b
sc00b's Avatar
there is a thread that explains this in a few easy steps
Old 03-20-14, 11:30 AM
  #49
carderoni
carderoni's Avatar
Thanks doodlebug and yardie - the instructions and that video made it very easy for me to change my lane change settings on the first try.
Old 03-20-14, 12:10 PM
  #50
zabone
zabone's Avatar
thanks for the video.
You don't need to have the engine running prior. just hit button twice. and follow the video.
Old 03-21-14, 03:17 PM
  #51
smardav
smardav's Avatar
Thanks all.. I'm gonna try to do it soon.
Old 03-21-14, 03:24 PM
  #52
smardav
smardav's Avatar
It works!!! I'm so happy. Thanks to toyotatom and yardie876 for the help.
Old 03-21-14, 05:43 PM
  #53
yardie876
yardie876's Avatar
No prob! After my dealer spent 45 mins trying to figure it out I figured if give it a go before I found the video. After a few drinks and the neighbors looking at me screaming to myself in the car I got it working.
Old 03-21-14, 06:11 PM
  #54
markb3
markb3's Avatar
I just changed mine from 3 to 5. Thanks guys. I may change it back to 3 if I don't like it but I'm loving it right now at least.
Old 03-21-14, 06:13 PM
  #55
Joeb427
Joeb427's Avatar
Originally Posted by yardie876
Look at this video:
http://youtu.be/W0NG0rnnjnc
Great video.
Makes the change a lot easier.
Old 01-24-18, 08:47 PM
  #56
Drawblood
Drawblood's Avatar
Works great on a 2017 IS 300 F-sport. I had to try it 4 times and it finally worked.
Please note, the last step is to actuate the left turn signal. It should actually read left change lane. Don't do a full two clicks down, just do the one click like you were going to change lanes. Also, setting the flasher count with the intermittent wiper control...even though I had mine set one from the bottom (for 5 flashes) I clicked through all of them and stopped on the second from the bottom before proceeding to the left lane change step.
Hope this helps if some of you were stuck.
Old 01-26-18, 12:39 PM
  #57
LexoticJ
LexoticJ's Avatar
anybody recently did this?
Old 01-26-18, 04:21 PM
  #58
gbgary
gbgary's Avatar
this video works...but when you do the little test, before turning the car on, you need to lightly touch it down twice (not once as in the video). works great on my 2016 IS.
Old 01-26-18, 05:56 PM
  #59
lexuscanuk
lexuscanuk's Avatar
Got mine working with the video. Thanks!
2014 is350 executive package
Old 01-27-18, 03:23 PM
  #60
Tolerant
Tolerant's Avatar
1.) Ignition off, doors closed
2.) Hold the wiper switch in the full up position. (this is the wiper off position)
4.) Hold wiper switch in the full up position for 5 seconds
6.) Move the wiper switch back to the full up position, hold for 5 seconds
8.) Move the wiper switch back to the rest position (neutral)
If this was done correctly, the right turn signal will flash once.
To adjust how many flashes you want, you change the intermittent wiper speed switch. P1 starts with the speed switch all the way at the bottom, P4 will be the top speed. This is found on the wiper stalk.
P1: 3 blinks
P2: 5 blinks
P3: 7 blinks
P4: Function turned off
Set the intermittent wiper speed to the desired setting.
Use the Turn Signal stalk and push down like you want to activate the left turn signal, the flashers should activate
If the turn signal blinks once, you change it to the "3 flashes" setting
If the turn signal blinks twice, you changed it to the "5 flashes" setting
If the turn signal blinks three times, you changed it to the "7 flashes" setting
If the turn signal blinks four times, you turned the function off.
Once this is done, cycle the ignition switch off, and back on, and it should be changed.
Worked perfectly for me ! Thanks
Quick Reply: How to: Changing Lane Change Flasher from 3 to 5 or 7
