MERGED SNOW tire and rims discussion
Old 11-01-16, 09:12 AM
  #181
otakusan
otakusan's Avatar
Blizzaks WS80 does come in stock size, but speed rating is not as high (H).
Other choices are Michelin Pilot Alpin PA4 and Perelli Winter Sottozero both V speed rating
Old 11-25-16, 02:39 AM
  #182
jeeper2269
jeeper2269's Avatar
Default Best winter tires for AWD 350 f sport?
having the all wheel drive creates issues for purchasing tires. Having 19" staggered creates even more of an issue. What are you guys running for 19"
Old 11-25-16, 08:01 PM
  #183
Answer
Answer's Avatar
Just go with a 17-18" square setup. I'm running 17x7 +35 with 225/45-17 Blizzaks on my 350.
Old 11-28-16, 07:35 PM
  #184
Flashkid
Flashkid's Avatar
Default ----------
Old 11-28-16, 07:44 PM
  #185
Answer
Answer's Avatar
Go with 17" wheels with 225/45-17 tires all around for winter. If you stay on 18", you're pretty much stuck with OEM tires sizes (you could go with 225/40-18 all around, but it would look funny at the rear).
Old 11-29-16, 04:10 AM
  #186
Answer
Answer's Avatar
225/45-17 is the same overall diameter a OEM so speedo won't be affected.
I'd suggest 7-8" wide wheels if you are going 17". The important thing is a low offset to clear the brake calipers. And yes, non staggered for the winter makes it more easy on everything.
I'm personally running 17x7 +35 RWC wheels with 225/45-17 Blizzaks on them.
Old 11-29-16, 06:16 AM
  #187
dilanp13
dilanp13's Avatar
Originally Posted by Flashkid
Thanks! That's what my buddy said to me so I wasn't sure. Would that mess up with the speedo calibration? I'm a newbie. Also what rims do I get? 17x8 or 17x8.5? No staggered?
Noticed you're in Toronto. Here's the setup I went with for a 2016 IS 300 F sport.
http://www.kijiji.ca/v-tires-rims/ci...?channelId=104
Old 11-29-16, 03:51 PM
  #188
Answer
Answer's Avatar
17x8 +45, would that be fine or should I go with a lower offset? Just want to preserve stock as possible. Only reason I'm switching to winter tires because of weather condition and also, my current stock tires are rubbing manholes and potholes.
This will all depend on how the wheel is made, particularly the spokes. I had to try 5 different models before finding one that fitted. And oddly, it was the skinnier of them all.
Old 11-29-16, 06:04 PM
  #189
rL-gT
rL-gT's Avatar
My car on stockies with 225/40 & 255/35 18s
Moms car with 225/45R17s on IS250 rims
Old 12-04-16, 06:30 PM
  #190
goldengame
goldengame's Avatar
I also had a 17" square setup on my 350 AWD with Blizzak WS-80s. Worked really well last year.
Old 12-05-16, 10:52 AM
  #191
computerwi
computerwi's Avatar
You should probably downsize to 18" at least. If you're looking for "performance" winter tires, the Michelin PA4 are great and fit on a square setup. Excellent on dry pavement and slushy snow but only so-so on ice. Super quiet and much better handling than the crappy stock Bridgestones.
Old 12-05-16, 11:41 PM
  #192
SilvrBulet
SilvrBulet's Avatar
Using an 18" square setup on mine. Michelin X-ICE 13s 225/40/18s. Not as good as the Blizzaks performance wise but better on tread wear. Usually don't get huge amounts of snow in my area. Many of my friends have the Blizzak WS80s like the posters above and swear by them. They're rated one of the best winter tires.
Old 12-06-16, 02:10 AM
  #193
robert2423
robert2423's Avatar
im running blizzaks ws80... They are great having drivin in the snow already with them... but they are noiser than hell on the freeway honestly...
i would be differnt and try a winter performance tire... i really like these Michelin pilot alpin. we are awd so i think this tire would be better for those dry days.
Old 12-06-16, 05:13 AM
  #194
Slackbus
Slackbus's Avatar
I just put Michelin Aplin PAs on my stock rims. So far the road noise and vibration seem better than the stock tires, not something I was expecting out of a snow tire.
Haven't had a ton of snow yet, but absolutely no problem on our first 5cm snow fall this week.
Old 12-06-16, 07:06 AM
  #195
robert2423
robert2423's Avatar
how much was your set?
Quick Reply: MERGED SNOW tire and rims discussion
