MERGED SNOW tire and rims discussion
#331
Blizzak is generally reviewed well, can't go wrong with it.
It depends on how snowy it gets, but I have had no problem running a high performance A/S tires year round. Michelin Pilot Sport, BF Goodrich G-Force, Continental DWS should do fine in most snow weather. My city does clear snow pretty quickly most days tho.
Just use caution and don't go all out and you should be fine. I even survived one winter season with the stock Turanza lol (Not recommended).
#332
I've used Blizzak's on my old 2010 IS250 RWD with no trouble using snow mode, I will be using my old set on my 2018 IS300 AWD.
Use snow mode and drive the car like a corolla and you will be fine, snow mode will make it feel like one anyways
#333
Went with a square setup for winter on my 2014, figured it would allow me to rotate the tires.
The simplest solution (for me) was to just go to tirerack.com and pick a set of wheels and tires (I’ve gone with 17” wheels and Michilin X-Ice). I’ve done this on 3 cars, the wheels and tires come premounted and balanced (and TPMS installed). Makes it easy to swap between summer and winter (other than the 3IS makes you reload the TPMS IDs on each swap, talk about a stupid design choice. The wife’s Mazda doesn’t use sensors in the wheels, but uses the ABS system to detect rotational differences between wheels. And my Jag simply relearns the IDs on its own after a few tire revolutions).
#335
I’ll chime in and say that the IS 300 RWD (200t) with Pilot Sport A/S 3+’s in snow is a little scary lol. You basically have to drive super slow if you don’t want to slip and slide everywhere. Also, I couldn’t make it up the hill to my house with traction control on, I had to turn it off and spin my wheels to get up. Definitely recommend going with winters. This is in South West Germany where it doesn’t even get that bad.
#336
Thanks for all the suggestions. Luckily, Tire Rack is running a deal on Blizzaks for the square setup that I'm looking at using, so I guess that answers which tire I'm getting! Also, I'm using Pilot Sport A/S 3+'s atm and they are definitely not appropriate for winters in the Midwest. I've also put about only 10,000 miles on my Pilot Sports and they currently sound like a plane taking off...so they are definitely not a repeat purchase for me. That complaint's for another day, though! Can anyone share whether they think 17 x 8 is an okay square setup for the rest of the year, too? Or should I look at something like 19 x 8.5? I love the staggered look, but I don't love the cost of not being able to rotate
#337
#338
[QUOTE=ISMinn;10636707]I've also put about only 10,000 miles on my Pilot Sports and they currently sound like a plane taking off...so they are definitely not a repeat purchase for me. /QUOTE]
Mine too, it got pretty loud and also the inside wears is really severe. Apparently Michelins doesn't play nicely with some IS and this is a bit of a known issue according to my dealer. I will be trying out BF Goodrich G force comp next, had a good experience with them on my previous car.
Nothing will make me go back Turanzas lol.
#339
ISTreeFidi (10-22-19)
#340
225/40r18 on still rims square off/2019 Lexus IS 300AWD
Kinda new in this forum...I just had a square off on my winter tires 225/40r18...would this affect or had any issue since the original tires on the rear is 255/35r18...appreciate any thoughts about this one.
[/QUOTE]
[/QUOTE]
#341
damn, son.... What is the point of raping tires like that?
#342
I haven't seen any pics, but either way I'm going to have 215/45/18 winter tires on my F Sport rims.
A bit concerned about the stretch, but the higher sidewall should somewhat compensate for the narrower tire, so I believe the stretch will not be hugely different from 225/40. Will post pictures if they're mounted.
#343
A 215/45/18 tire i recommended for a rim width of 7-8 inches, with 7 inches being the ideal fitment.
The rear F Sport rim is 8.5 inches...1.5 inches over the ideal fitment, and 0.5 inches over the recommended max.
Ultimately the decision is yours, but hoping the additional info my lead to a safer tire size choice for the rear at least.
#344
For the front 18x8 F Sport rim it's not an issue, but the rear 18x8.5 rim that comes with a 255/35/18, it's gonna be a stretch.
#345
the original front wheels are 18x8, and the rear ones are 18x8.5... but it is the offset that might get ya. Try to remove the rear wheel and put it on the front to see if you have any issues. Might as well drive it a bit to see if rubs/scrubs/makes weird noises anywhere...
ISTreeFidi (11-16-19)
