Paddle Shifters
Old 10-05-13, 11:39 AM
aTeAse
aTeAse's Avatar
Default Paddle Shifters
Anyone here use this on their 350 F Sport?
Does the paddle shifter and manual gearbox have the same gear ratio?(or is one faster than the other?)
Once redline is hit, will it automatically shift up for you?
Old 10-05-13, 12:03 PM
John510
John510's Avatar
There is no manual gearbox. Paddles only.
Old 10-05-13, 01:20 PM
aTeAse
aTeAse's Avatar
My mistake. I meant the (M+/M-) where the shift **** is.
Old 10-05-13, 01:33 PM
2GSKaizen
2GSKaizen's Avatar
The gear ratios of the transmission are fixed. They can't be changed. The shifter paddles and the stick (when it's in M+/M- mode) are just acting as electronic switches that tell the transmission to shift up or down. There is no difference in speed between regular D, or M+/M- when you put your foot to the floor. On the lexus's with M+/M- they will let you bounce off the rev-limiter without shifting up for you. On cars like the ES 350 or 2nd Gen IS, when you knock the shifter over to the left to put it in manual mode, it actually gives you an S instead of an M on the gauge cluster. These cars, I believe, will shift up to the next gear if you try and push the engine past redline.
Old 10-05-13, 02:05 PM
aTeAse
aTeAse's Avatar
Thanks for the info.
But in other words, the paddle shifters and the stick is just for extra fun? lol(which i completely dont mind)
Will it at least save gas overall?
Old 10-05-13, 02:42 PM
John510
John510's Avatar
You will most likely use more gas using the paddles. To save gas keep it in eco mode. In eco mode I average 26 mpg (which is pretty crappy for a 2.5 ltr V6)
Old 10-05-13, 03:58 PM
2GSKaizen
2GSKaizen's Avatar
yeah leave it in D and let the computer work to get you the best mileage in eco.
Old 10-05-13, 04:33 PM
aTeAse
aTeAse's Avatar
My hopes for having fun with the gear box is shattered.
I'll just play with it when I go on dates then. haha
BeEvil
GX - 1st Gen (2003-2009)
03-13-18 08:02 PM
jamodeo
03-14-15 06:01 AM
boukaal
06-02-14 09:31 AM
GiGAS
Performance
23
07-26-12 12:20 AM
Hostile
SC- 1st Gen (1992-2000)
07-17-11 08:02 PM
Quick Reply: Paddle Shifters
