Wheel fitment
Anyone here have knowledge on the sizing that will fit with the 3IS?
Rim size/ how wide/ and what tire sizes.(information for lowest rim size vs largest rim size if possible to keep an accurate odometer)
Thanks in advanced.
Thanks in advanced.
I think the 2013 and 2014 Lexus IS can use the same wheel specs if that is the case the following Vossen 20" wheel specs below work.
Front.
5x4.5/114.3 32 mm
or
5x4.5/114.3 38 mm
Rear
5x4.5/114.3 45 mm
Front.
5x4.5/114.3 32 mm
or
5x4.5/114.3 38 mm
Rear
5x4.5/114.3 45 mm
Former Sponsor
it all depends on the size of the wheel and if you are lowered or looking to lower
here is the basic information for you vehicle
Bolt Pattern: 5x114.3 also known as 5x4.5
Now for the 3IS
depending on the fitment you are looking for
We have done the 20" Vossen wheels
using the following specs
Front: 20x9 + 32
Rear: 20x10.5 + 38
for 19"
we have done
Front: 19x8.5 + 24
Rear: 19x10.5 + 38
it also depending on the wheel you are after.
Now for the 3IS
Front: 20x9 + 32
Rear: 20x10.5 + 38
for 19"
we have done
Front: 19x8.5 + 24
Rear: 19x10.5 + 38
while we are on the subject of wheels i have a tire question..
first off i am seriously considering getting a set of the LFA style wheels in matte black found on ebay in the 19" 8.5 front and 9.5" rear.
i am very **** about my speedo and tire diameter being as exact to stock as i can possibly get.
what tire size will fill a 8.5 front rim so the sidewalls are square to the lip, not over wide and not narrower than the 8.5 width and same for the 9.5 rear wheel.
i would like to price some tires before i get the wheels ordered.
so i want to know what tires have the same diameter whatever that is and when mounted are 8.5" wide and 9.5" wide
thanks!
thanks!
I use to be into the low offset/VIP style look, but I cannot stand to drive that carefully anymore.
Anyone here seen the project gs from five axis?
If so, what would you call that 'look'?
I'd prefer function and form. If possible. I'm just getting back into the game.
thanks!
thanks!
Guest
Posts: n/a
Vossen debuted first with wheels in the USA and let everyone else know what works on the 2014 IS...see the latest video below... As others have stated it depends on the look/feel you want.
Utterly superb![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](https://www.clublexus.com/forums/attachments/is-third-generation/300913d1381436283-wheel-fitment-9673646602_89d892d53e_b.jpg)
