3IS Battery Drain (merged threads)
#676
Mine had the new gateway ECU too but the battery still drained when I didn't use the car for a week. This time they replaced the battery because they said it was frozen (this was during we had a stretch of sub zero temps). Car is stored in an unheated garage.
#677
any issues after that?
#678
So far so good. But I have been making sure to start the car at least once a week if I'm not using it. I also have been using the door switch instead of the remote to lock the car.
So not sure if the problem is totally gone or it's just the above practices mitigating it.
#679
So far so good. But I have been making sure to start the car at least once a weeks if I'm not using it. I also have been using the door switch instead of the remote to lock the car.
#680
Getting my first taste of this battery drain phenomenon.
Literally had my car at the dealership for its 30k service 3-4 days ago, and now my battery is dead. Interestingly, they neglected to perform the "Check Battery Performance" portion of the vehicle's report card.
Sad day. Luckily it's still under the original warranty I guess.
#682
After almost 4 years of fighting and 2 dealers. 3 batteries replacement. Apparently each time the battery threw an error so they kept replacing it. On the 4th time last week, the battery was tested okay so they finally have a reason to give me a new Network Gateway ECU this morning.
I was also able to duplicate the issue. If I lock the car using the remote over night the car will die the next morning. Normally, I lock the car using the handle. My car is garage kept and the key is one floor up from the garage. Concrete floor! But apparently the range is enough for the car to be talking to the remote. Either that or the car is stupid and kept pinging the remote. Who knows. But locking using the remote will drain the battery. It’s too bad it took almost 4 years to finally be able to consistently repeat it.
#683
So is this battery drain issue still affecting 2017 and 2018 models?
#685
#687
well, another battery bites the dust last night, previous replacement was done back in June 27 2016, 10k miles ago. it was replaced under battery warranty both time.
my car is 2014 IS 350 F sport w/ nav
#688
only took another 11 days for the fifth battery to fail, stealership finally replaced the gateway ECU
2014 IS350 F sport
08.30.2016 - 1st battery replacement
06.27.2017 - 2nd battery replacement
11.26.2018 - 3rd battery replacement
12-06-2018 - 4th battery / gateway ECU replacement
2014 IS350 F sport
#689
Just had my 2014 battery die on me. Battery was less than a year old. I took it to the dealer and they confirmed the Gateway ECU was drawing power and will replace with the new PN per the LSB. My car was in the VIN range and has BSM.
Has anyone had the issue continue after replacement with new ECU?
#690
Can I purchase the correct part number for Network Gateway ECU (89100-30160) and replace this myself? Do I need to do anything to program the car to accept the replacement Gateway ECU? My car is past warranty and even with a new battery, the car won't start if I let it sit idle for more than 2 days.
The replacement looks fairly straight forward, just wondering if anyone has done this themselves on an 14-15 IS. Looks like its been done DIY successfully on a GS. https://www.clublexus.com/forums/gs-...ery-drain.html
