K&N OEM replacement air filter for IS250???
I normally buy a car a replace the air filter with a factory fit K&N from day one but in the case of the new IS I can't find it and the K&N website doesn't have it.
Does anyone know if the old IS250 air filter is the same?
The pursuit of F
You might have to do some digging. Search for pics/part # for the 2IS 250 filter and compare with the 3IS... If you see a match at minimum in dimensions (as part numbers may change despite being the same item), my conclusion would be that it's the same and will work. Good luck
Thanks for heads up! It is the same as the old GS and posted on the K&N website just last week.
I put it on Saturday. I must admit, it has a larger effect on larger engines than in the 250, but it does give a little extra kick.
Sithel
05-23-12 01:35 PM
PCP20
04-26-08 10:11 AM
