F-Sport Brakes
Received 1,064 Likes
So even though the rear mounting location changed, all the caliper parts remained the same??
If so then yes, this is great news since you can easily mount the entire 2IS F-Sport BBK onto a 3IS.
You should also be able to do the same with the older Brembo BBK's as well.
The OEM IS-F BBK will fit as well, with some modifications.
~ Joe Z
Looks so great! I saw them on Sewell, quiet expensive!!!
Do you also change the rear side? Would the brake force uneven with nodding head, cause front force is too strong?
jkwan18
08-14-08 08:44 PM
