Gas tank range?
My fuel gauge problem fixed. Just have to replace with OEM fuel pump and sender unit. The problem went away but now I have other problem with the check engine light come up and back to the mechanic. The OBD-II code reader came up a few codes starting with C and then there is a P code. Now the mechanic thinks it is the air valve and intermittently while driving the RPM rev high and then switch to new gear. He thinks by replacing this air valve will solve this issue. I have no problem fixing what needed, after all this is a 2007 vehicle and these are normal wear and tear. Any comments? Please let me know.
This is the 3IS forum (2014+), and your question is about a 2007 GX?
