Wiring diagram is confusing.
11-10-13, 08:35 PM
Need to know which wires are the sub wire to tap into. the colors dont match up right.
11-12-13, 07:38 PM
Can anyone take a pic of what wires they connected to their LOC? Really need help
11-12-13, 10:16 PM
Yes. I drove the LFA.
I will be doing mine this weekend... according to my wiring diagram, there are two wires going to the factory subwoofer. Pin 6 is gray (+) and Pin 21 is light blue (-)... hard to count in your pictures, but they look to be side-by-side...
11-13-13, 07:04 PM
Do you know where to start counting the pin from? I had this diagram and I was gonna go off pin location but it doesn't make sense.
11-13-13, 08:23 PM
Im going off of factory wiring diagrams... im 99% sure im correct with the gray and blue wires that are right next to each other in your picture. Counting in the top row, from right to left (left to right if you unplug it and look at the pin side), the 6th pin in Gray. There are 15 in the row.. starting in the next row, count 6 in to get pin 21.. its a blue wire. There you go.
11-14-13, 12:13 AM
So you're only tapping into one set of wires? Don't you need a left and right?
11-14-13, 05:38 PM
So which would be the ground?
11-14-13, 07:16 PM
I meant which one is the remote. I tapped into the big orange one, 3pink ones and no luck
11-14-13, 07:30 PM
is this the non-ML version ?
11-14-13, 07:51 PM
11-16-13, 06:20 AM
Quote:
Originally Posted by
Lancelot24
Yes the non ml
Did you figure out which wire to tap into for the remote turn on? Thx
11-18-13, 10:43 AM
Goodlife
nope still searching for answers
12-28-13, 11:19 AM
Use the skinny white wire for the remote. Works like a champ[IMG]
[/IMG]
Ltaboso
04-01-24 07:07 AM
Timmy2k
05-26-14 08:44 PM
kumquatism
10-18-11 12:51 PM
supra_trd
03-20-09 02:48 PM
