Voice command
Old 11-11-13, 02:53 PM
aTeAse
aTeAse's Avatar
Default Voice command
Anyone using voice command know how to disable the computers initial response?(before the beep).
I'm trying to just get the beep right after i click the voice command button.
Old 11-11-13, 03:11 PM
redraptor
redraptor's Avatar
Try pressing the speak button 2x, it will skip the initial response i believe.
Old 11-11-13, 04:01 PM
abcsoup
abcsoup's Avatar
Originally Posted by aTeAse
Anyone using voice command know how to disable the computers initial response?(before the beep). I'm trying to just get the beep right after i click the voice command button.
If you click the voice command button once, the main nav screen will change to the voice command screen. Then, you can use the "mouse" to enter the settings menu (I think it's just a cog in the lower left corner). There is an option that disables the voice prompt somewhere in there.
Be aware that it will no longer give you much guidance on how to use the system if you disable it, so it might be worth getting used to everything first if you're new to the car. However, it does make things much quicker to access such as entering an address.
Old 11-11-13, 11:32 PM
aTeAse
aTeAse's Avatar
Can't I simply just enable it?
Old 11-11-13, 11:43 PM
abcsoup
abcsoup's Avatar
Yeah you can always reenable it if it gets too cryptic. After I disabled it, I got confused more than once when I wasn't sure what kind of response it was expecting (yes/no, etc.). However, you can usually look at the nav screen for some hints about the current voice commands, but then you have to take your eyes off the road.
alien8u
RX - 3rd Gen (2010-2015)
08-05-18 05:49 PM
satnav
12-01-12 04:33 PM
rftuck
09-16-09 10:47 PM
Lex350
ES - 5th Gen (2007-2012)
09-22-06 11:19 AM
TopContndr
08-08-06 02:58 PM
Quick Reply: Voice command
