The heat doesn't work well in my IS250c
Old 11-19-13, 01:33 PM
scrapper
scrapper's Avatar
Default The heat doesn't work well in my IS250c
I'm disappointed with the heat in my 2012 IS250c. Any others experienced the same and any solutions?
The vents never really seem to blow hot, even at the top setting of 85 on auto. Therefore, I always wear a jacket in weather less than 70 degrees. By the way, this is with the roof up.
Roof down? The heat is non-existent.
Bought the car new in October 2012 and less than 15K miles. No other troubles.
Old 11-19-13, 01:47 PM
NYKnick101
NYKnick101's Avatar
bleed the coolant as there could be a ton of air in the system to make the heat hot enough. Also try the heat with out the auto button. Auto sometimes engages the AC even wen on 85 so try it with out it
Old 11-19-13, 04:41 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
This should be posted in the 2IS forum. Good luck!
ehc0720
RX - 3rd Gen (2010-2015)
16
02-25-18 07:48 PM
comis
CT 200h Model (2011-2017)
11-30-13 12:42 AM
BlkGS3
11-14-05 06:01 AM
lexusdr
GX - 1st Gen (2003-2009)
03-06-05 09:33 AM
brent0226
05-22-04 11:19 AM
Quick Reply: The heat doesn't work well in my IS250c
