Wheel specs of stock F sport 18" rims
The following 2 users liked this post by iampraneel:
MGa (03-01-19),
phongtphan (05-12-18)
I have a 2012 IS350 AWD
Do the 235/40/18 cause any issues with the speedometer?
I'd like to upgrade to 18" wheels for the summer and would much prefer going slightly wider to 235.
Blast from the past - Hub Size on the 2IS?
OEM F-Sport Split 5 Spoke
Pattern = 5 X 144.3mm
Front - 8.0 X 18" w/45mm offset factory 225/40R18
Rear - 8.5 X 18"w/50mm offset factory 255/40R18
Still, Hub bore size???
JJD952 2IS F-Sport Wheel Size
EDIT: Maybe bore is 60.1mm? But that site said 8x18 / 8X/19...
Received 1,735 Likes
Hub size is 60.1mm.
Bolt pattern is 5X114.3 or it may be listed as 5X450...it's the same as one is millimeters and the other is inches. Most commonly it's listed a 5X114.3 though.
Rear - 8.5 X 18"w/50mm offset factory 255/35R18 (the sidewall profile was the only difference from your post above)
As for a 255/40/18, might rub and is likely just a hair too big for a 8 inch wide wheel.
The following 2 users liked this post by Sasnuke:
2013FSport (09-25-17),
Oneops (12-07-23)
