The owner's manual is not so great in its description of the lighting. Your DRLs come on when your parking brake is released, and stay on until you either turn the switch to DRL Off, or turn off the ignition.
^^^ Right on...
Originally Posted by 18017
I was confused, because when I start my car, the DRL's don't turn on. Manual says they should but mine don't. They turn on when I get out of P and its set on AUTO
The Parking Brake Pedal disables the DRL on first startup...
So try the scenarios again with Parking Brake engaged / disengaged on Start Up..
I have a 2014 IS250. Do you know if the DRL has a blub that can be changed? If so, do you have a picture of the location and bulb type? I only see the LED replacement housing with bulbs already installed on eBay. Thank you.
