Ultra white and tire shine= no go???
As people have already mentioned... the issue is that the dealerships simply use poor quality products. In fact, I would NEVER let the dealership detail or wash your vehicle!
A water based tire dressing is important. Water based dressings will work to nourish your rubber and keep it looking great for longer periods of time. Water based dressings may need to be reapplied more regularly than silicone based dressings, however they are much safer and (IMO) look much better too.
My favorite go-to tire dressing has been Optimum Opti-Bond Tire Gel.
I have a review article that will be published on Jan 8th about this product and I'll be sure to post the link!
Tuf Shine is in fact a nice product... the key (like with any detailing product) is preparation. If your tires are not incredibly clean, the tire coating will not last long at all. Be sure to use the Tuf Shine Tire cleaner and repeat several times if needed until they are completely clean.
You will still need to apply a new coat of the Tuf Shine Tire Clearcoat every couple of months to maintain a nice, glossy look.
I've heard good thing about Tuf Shine which is permanent tire shine. I just ordered the kit and report back how it goes. There are a lot of positive reviews on this product. I like the idea of permanent shine without having to keep applying after a car wash. Definitely something to consider.
http://tufshine.com/
While I know and believe there is a problem here, this entire situation makes no sense. All paint colors get the same final clear coatings out of the factory. So I don't get what makes this a problem for Ultra White. Could it be all other colors are also getting stained but we are just not seeing it due to the darker shades? I'd think someone with Starfire would be complaining too. Again, I don't see what makes Ultra White different...
Tire dressings, especially oil based products, have a tendency to sling from the tire and onto the paint when applied too heavily or when they are not allowed to dry before the car is driven. Oil based products (since they are more resistant to water) may be a bit more difficult to remove so someone may perceive it as a stain that has set into the clear coat.
Water based dressings are easier to wash away if they should sling onto your paint, however with proper application this should not be a problem.
![](https://scontent-a-ord.xx.fbcdn.net/hphotos-ash2/t1/557200_10151090589267363_157786013_n.jpg)
^I used to use Meguiar's endurance gel quite often because I liked the look, and I never had an issue with 'staining' or slinging because I would allow the product to dry properly before driving the car. If there was excess product on the surface after an hour or so, I would gently wipe it away with a microfiber towel.
Sometimes less is more, sling can be caused by to much shine applied, and not reading instructions. Some tire shines tell you to wipe off excess and let car sit for a while to allow shine to sit dry and soak. I use wolfgang tire shine which is water based and its pretty damn good.
I don't know what dressing dealer used but this was back in July from tire dressing. This area was completely cleaned, I even waxed, used scratch remover, iron remover, clay bar, nothing was making these marks going away. They're almost gone now after a few months, not sure if it's just UV. Kind of looks like dye from hair color that's impossible to remove but overtime it just fades away.
Trust me this is a common problem on white cars. Google it and you will see a ton of results. People have this problem on other white cars not just Lexus.
http://g35driver.com/forums/care-det...ng-stains.html
http://forums.corvetteforum.com/car-...tic-white.html
http://mbworld.org/forums/detailing-...ng-stains.html
![](http://farm4.staticflickr.com/3715/9280544024_699bc892eb_b.jpg)
As promised... here is my product review for Optimum Opti-Bond Tire Gel
Product Review: Optimum Opti-Bond Tire Gel
![](http://farm6.staticflickr.com/5478/10519373196_d875bbd3ff_b.jpg)
^After 2 coats of Opti-Bond. Tires are dry to the touch. No slinging, no mess, looks great... read article for more info!
-Zach
-Zach
Justin2JZ
Automotive Care & Detailing
33
03-07-15 12:24 PM
