Front Camera Install
Old 02-14-14 | 01:29 PM
cb80923's Avatar
cb80923
Push a stiff wire / coat hanger through this hole on the passenger side. It goes through to the driver side along the passenger/engine compartment wall. Then get under the driver side and you will see your wire sticking through above the gas pedal. I pulled 1 wire at a time so I wasnt trying to pull a bundle through at once.
Attached Thumbnails Front Camera Install-screen-shot-2014-02-14-at-1.27.30-pm.png
Old 02-14-14 | 02:02 PM
dojoman's Avatar
dojoman
Thanks! Let me check it out.
Old 02-14-14 | 02:53 PM
2014IS250's Avatar
2014IS250
Great write up bro! Thanks for posting!
Old 02-14-14 | 03:12 PM
dojoman's Avatar
dojoman
Has anyone used Aux port to watch video? I'm reading the owner's manual and it doesn't say I need to have the parking brake on in order to show video, only DVD on ML system requires. Unfortunately, I don't have the 3-pin RCA cable to test it. I want to put the front camera video on the Nav screen using Aux.
Old 02-14-14 | 03:33 PM
JGard18's Avatar
JGard18
Great idea and very well executed!
Old 02-15-14 | 04:53 AM
leoben's Avatar
leoben
I have no NAV (so no reverse camera).
It could be a great idea to use the A/V in for that video!
Today I'll check with my Sony camcoder and if it works without having parking brake on, in the next days I'll buy a reverse camera. I need only to know if it's possible (and how) to switch to A/V in when I use reverse gear...
Old 02-15-14 | 12:53 PM
dojoman's Avatar
dojoman
Thanks. Let me know how it goes.
Old 02-15-14 | 01:12 PM
leoben's Avatar
leoben
Doesn't work...
I tried to connect a Panasonic camera. I get the A/V rca cable included and connected to the car with an rca to plug adapter cable. Nothing was displayed. And there was a strange noise (like a buzz) coming from the back of the connector in the armrest.
The camera connected to a Samsung lcd tv works good. Maybe the problem is in the plug. I don't know what type I have to use... 4 pin (video+stereo audio) or 3 pin (video + mono audio)...
Old 02-15-14 | 01:16 PM
dojoman's Avatar
dojoman
Doesn't work...
It's 4-pin video + audio. Maybe yellow isn't video? Sometime red plug is used for video.
But you didn't have to press the parking brake?
Old 02-15-14 | 01:21 PM
leoben's Avatar
leoben
I've connected the cable for just a second and unplugged it after hearing that noise...
Give me 5 minutes, I go out to check if video is on red plug!
Old 02-15-14 | 01:32 PM
leoben's Avatar
leoben
You're right, video is in red plug.
But.... no video is displayed if parking brake isn't pressed
It's like when you watch video from usb
Old 02-15-14 | 01:56 PM
dojoman's Avatar
dojoman
That sucks. Thanks for update.
Old 02-15-14 | 02:00 PM
leoben's Avatar
leoben
No mod available to solve parking brake "issue" and always show video ?
Old 02-15-14 | 02:30 PM
dojoman's Avatar
dojoman
Nav override device can bypass all the restrictions but center console must come out in order to hook it up. Not sure if any cable has to be splice, I wouldn't go this route just for the camera. For the backup camera eBay sells lots of wireless module with LCD screen. You may have to think about this since we can't use Lexus screen.
This company sells wireless cam and you can use wifi on iphone, ipad or ipod to show video from camera. It looks interesting.
http://4ucam.com/iphone-android-ipad...up-Camera.html
Old 02-15-14 | 11:47 PM
specONE's Avatar
specONE
wait are you sure we can watch video from USB?
i've tried, doesnt look like it works for me.
