need to disable pcs immediately !
Old 02-18-14, 11:51 PM
SunnyPanx
SunnyPanx's Avatar
Default need to disable pcs immediately !
Nearly got into my 3rd accident today because the system was triggered while i was switching lanes i was only going at 30 kph , the car applied heavy braking to a full stop without my control and the car in the back was about to ram me , i have no switch off button inside the vehicle so unless you guys know of a way to switch it off through the cpu ill have to take it to the dealership .
Let me know im getting fed up with this , might not be so lucky next time
Old 02-19-14, 02:51 AM
magne
magne's Avatar
You have a switch to disable it. It is placed under the steering wheel, at the very bottom of the trim, just above your feet.
Look it up in the user manual
Old 02-19-14, 07:06 AM
Bass Mech
Bass Mech's Avatar
i think if your having this problem you are following way too close. try leaving a little more room between you and the other cars. mine has never gone off like that.
Old 02-19-14, 08:51 AM
jhs82
jhs82's Avatar
Not my car either. It has warned sometimes, but never engaged the auto brake. Every time has been with less than 10m (30ft) between me and the car in front of me.
If you drive faster than the car in front of you, PCS will emergency brake your car. That's what's it's supposed to do. You drive with to little margin.
Old 02-19-14, 12:28 PM
Appleman
Appleman's Avatar
New thread next week: "need to replace grill and bumper"
I've only ever had the system brake and hold on me once, and that's when I was "playing" trying to activate it. I nearly rear-ended the truck in front of me and felt really stupid doing it. But at least I know how it works now.
Old 02-22-14, 10:50 PM
SunnyPanx
SunnyPanx's Avatar
thanks i found the switch and turned it off, probably saved my life and my car by doing so.
gus73
GX - 1st Gen (2003-2009)
10-20-17 01:56 PM
HellBound
10-07-16 09:15 AM
msgntsu
11-07-15 06:44 PM
crazych42
05-22-14 04:50 PM
Capirato
GX - 2nd Gen (2010-2023)
11-08-10 12:38 PM
Quick Reply: need to disable pcs immediately !
