Ownership and Daily Driver Comparison: IS 350 F-Sport AWD vs IS 350 F-Sport RWD
#61
Ok looks like the car shifts to 6th gear around 55-57mph in Sport mode.
When I was trying to figure out the speed I found out something interesting. Normally I switch to Sport mode when the car is in park as I figure it is cleaner to do it that way. On my way to lunch I started driving and realized I forgot to put it in Sport, so when I came to a stopping point I switched it. The throttle response appeared to be that of Sport mode but it shifted like Normal mode. I got up to 8th gear when I stopped accelerating. So I was in 8th gear at 40mph in Sport mode. This is full auto by the way.
On the way back I switched to Sport mode like I always do, in Park, and it shifted based on the speed I was going (55-57 = 6th gear, 67-70mph = 7th gear) which I thought was pretty interesting. Not sure why the shifting behavior changes when you put the car in Sport mode in Park vs Drive.
Makes me wonder what exactly gets turned on (for lack of better wording) and what doesn't when you change modes when the car is in drive.
Can you try doing it again, intentionally and report back your findings?
Side note: I personally believe that it's plausible the ECU is limiting performance for a preset amount of time/mileage/or other dynamic factor. But, your engine will continue to "break-in" as it ages, which will increase power output and efficiency. The first few hours of a fresh engine's life determine it's future - This is due to the proper seating (or lack thereof) of the piston's rings. After that, the engine's bearings/cam shafts and direct contact parts will continue to "wear-in", thus increasing power/efficiency. This could be what you're feeling. Does it seem like a light switch? Because if it's directly from wear-in, the increase in power/efficiency would be gradual and like barely noticeable.
#63
You don't lose much with AWD
I don't have as much time behind the wheel in both variations as the OP, but I did drive the RWD for an hour, and ended up getting the AWD (both 350 F-Sport). Admittedly the 8-speed shifts slightly quicker, and feels like it provides slightly better acceleration from a stop. I would bet that the extra weight in the front of the car inhibits the handling slightly at the limit for the AWD too.
But, I think it's important to realize that you probably get 95% of the performance and handling with the AWD version. So if, like me, you live somewhere that you kind of need the extra all weather traction, you really don't miss out on much. I've only had the AWD for a few days, but i'm totally loving it.
#64
I've noticed the opposite phenomenon with the throttles, actually. The gear ratios in the RWD's 8 speed are more aggressive than the AWD's 6 speed, especially first and second gear (by the time you top out 8th gear is about the same as 6th in the AWD), so off the line the throttle feels more sensitive in my RWD car than it did in the AWD car.
One reason for this that I could if is that the Lexus didn't want a too sensitive accelerator on a RWD as it would lose traction easily as compared to the AWD. Do you think this is possible?
Again, I observed this as I have the chance to drive both the cars back to back on a regular basis.
#65
Would you care to give your opinion about both cars? If I understand clearly you find the difference between RWD and AWD not as important as carderoni noted. I'm waiting for my RWD IS350 in 20 days and I'm still wondering if I made the right decision. As I stated in the other thread I'm in Montreal and we get similar snow conditions to yours but our streets are cleared within 12-18 hours and roads are flat. Would you buy your RWD again for the difference in driving dynamics?
#66
When you switch from Normal to Sport while driving, the car doesn't change throttle response or shifting points right away, and in Sport +the steering also become heavier gradually. I remember reading about this somewhere, which claimed that the car was programmed that way as sudden changes in those parameter would make the car less predictable to some.
I've not seen this happen in my travels with this fine machine. I switch to and from modes all the time while driving and while in park. They seem to do the exact same things to the driving dynamics, regardless of how I activate each mode.
What I see...
Cold start (car's been off for at least a few hours)
- While still in Park, turn **** to Sport/+ mode ...car shifts gears with typical Sport mode behavior
- Put the car in drive, stop car (still in drive), turn **** to Sport and it shifts like Normal mode for the first few minutes/miles and then switches to Sport mode shifting. I like to watch the gear the car is in on the Tach.
Warm start (car turns on with coolent still warm and low idle signature)
- It does not matter when I switch to Sport mode, it shifts like Sport mode
Driving in Normal mode and car is fully warmed up
So I think it's a combination of what you and Kuma are saying. I think the car's ECU is limiting full Sport mode until it is fully warmed up. Now it may only be limiting it if you switch from Normal mode to Sport mode while in drive, but the car's throttle response is definitely better once warmed up. Now whether that is the ECU limiting it or just natural mechanics on how autos normally operate who knows. Both make sense.
#67
This looks to be what is going on, though possibly more related to how warmed up the car is. I will go into further detail while responding to CTLG but I wanted to quote yours because it seems fairly accurate.
Yes, repeatedable ...with notes. Tho to answer your last paragraph first, I have 4500ish miles on the car and it is already starting to break in nicely. Gas mileage has already improved.
What I see...
What I see...
#68
The only time I faced trouble was during a snow storm in the Boston outskirts (Babson college campus to be specific). It had snowed heavily for 30 mins right after I parked the car and the temps were just below freezing leading to extremely slippery and slushy surface. Also, the Babson college area is hilly and the ramp out of the parking lot was steep (10-15 Degs gradient I would say). All these factors made it almost impossible for me to get the car out of the lot, which was maily due to the extremely sensitive TC of this car. I was able to get out once I turned the TC completely off and turned the snow mode on. Once I picked up speed, I had not issues even when the roads were steep.
I addition to the dynamics, you get better fuel efficiency and an electronically adjustible steering. (AWD has only manual adjustment as far I know). You would also be saving over $1500 which you can spend on winter tires with wheels and an Fsport exhaust. In short, you would be getting a better car for lesser money.
#69
This makes sense. I'll have to try this for myself. I've always put the car in ECO mode when cold, because I'm super-**** about pushing a cold engine too hard. Once the coolant starts to warm up, I'll switch modes if need be. It doesn't take long for the engine to warm-up to proper operating temps, it takes the coolant longer, so by the time the coolant temp starts to creep up, the actual engine is warm. The worst thing you could do to a totally cold engine is let it sit and idle until the coolant is up to normal temp. This is unneeded, unless you're going on a very short trip (like moving the car from one parking spot to another) - then allow the car to warm-up until the coolant temp starts to move up a few bars. This is especially important for a new engine. There is a fine line between allowing an engine to warm up and idling it for too long.
I do warm up the engine but only till the idle signature calms down (cold start it starts off around 1.5k RPM or higher) to allow proper lubrication. This is also about the same amount of time it takes for the car to see my phone and pair up - so about 30s. The one time I did get a Nav reboot it was when I shifted right away on a cold boot and tried to hit the volume button when the Warning screen was still on. So I wait 30s, which sometimes sucks I admit, allow the lubrication to set in and the phone to pair up and no issues. Only time I "warm up" longer than that is if I'm trying to deice my windshield in the winter time. I've heard the same thing you said that warming up the car is actually not good for the car ...not to mention it wastes gas.
So when I said a "warm start" I meant I just drove the car so the car has only been off for minutes or 1-2 hours and it's still pretty warm. Example, cold start going to lunch ...warm start coming back from lunch.
#70
Stickers and Specs
These two cars are about as identical as they come, save the obvious color and drivetrain layouts. For my second IS I wanted the exact same options as the first - no need for Mark Levinson or the kinda-sorta-funky VGRS system. NAV, Blind Spot, and an accessories package work for me.
Ultra White/Black AWD
Silver Lining Metallic/Black RWD
The Differences
The Differences
- $1,526.00
- Tire sizes are identical, but the AWD model rides on all seasons while the RWD version gets summers
- Door edge guards on the RWD model (an option I was not aware of until just now)
- $1,526.00 total
#71
VGRS just boosts the power steering assistance depending on your speed. Granted, it's a more accurate system than you'll find on most other cars, but I didn't find it necessary after driving the AWD car for a few months. If you like a very light steering feel at low speeds (like in a parking lot) it might be right up your alley. I'm sure others that have lived with it can give you a more detailed description than I can.
#72
#73
I haven't spent much time with a VGRS equipped car but it didn't seem to me like it imparted any more feedback from the road or steering feel. It's still an electric power steering system. A few of the members who have it swear by it while others thought it was kind of awkward in some situations, like on tight highway ramps.
#74
4,000 mile update
Just crossed the 4,000 mile mark so I figured it was time for an update.
Gas Mileage
This has been a hot topic on this forum from the beginning. After logging 5,000+ miles on the AWD vehicle I was averaging 20.9MPG according to the trip computer. Like many others I experienced improved fuel efficiency after logging a couple thousand miles. While nothing to write home about, this was a huge improvement over my Subaru Legacy GT, which was rated at 17MPG city, 22MPG highway, and probably saw about 18MPG combined.
As I noted in a previous post, I've been driving the RWD model in Sport and Sport+ mode more often - and pushing it harder - inspired by the more aggressive gearing and quicker shifting of the 8 speed transmission. Despite this I have averaged a surprising 23.8MPG according to the trip computer. Like the AWD version, this car has also seen improved fuel efficiency once the odometer clicked a couple thousand times. It's worth noting this car sees the same commute and same (roughly) 60/40 city/highway split as the AWD model, using the same JoeZ intake, with an oil change after 1,000 miles plus RSR Ran-Up.
Reliability
Not much to say here, really. The AWD car had a driver's side blind spot monitor failure around the 400 mile mark which was taken care of quickly under warranty by the dealership. No leaks, rattles, vibrations, or aberrations to report.
The RWD car has even less to report - it's been completely problem-free so far. I believe the BSM monitor on the AWD car was a fluke and, based on my limited mileage, both cars are as reliable and quality-built as a Lexus should be.
Other Stuff
As a side note, it's been nice to see a few more 3IS's on the road around here. Within the past couple of weeks I spotted a Matador Red RWD IS 350 F-Sport and just yesterday crossed paths with an Ultra White AWD F-Sport (unfortunately I could not get close enough to see if it was a 250 or 350).
Gratuitous beauty shot:
Gas Mileage
Reliability
Other Stuff
