Micro SD card
#31
Bought SD card from the dealer, P/N:PT219-GEN08-17. I followed the instructions provided by the service manager: With vehicle off, remove old SD card and insert new one. Then keep the vehicle ON and parked for an hour and not touch anything.
After 15 minutes no message appeared. Then I went into navigation options and selected update map. The following message appeared "Please change to the new map data SD card at any time". I do see 21-37-17 (2017-06-1) under map data, but no other message like "reading data" to verify the map actually worked.
2015 IS350
2015 IS350
#32
I think you can't clone it to a normal card but you can unlock those ebay cards, there's a Russian guy who did it, but it needs special software and special hardware below is the video
#33
I have 2 different kinds of cloning software I use daily for PCs. I may try it on my sd card just for poots and giggles...
I also found this a while back... https://www.backup-utility.com/clone...card-8523.html
MikeZero
01-27-17 11:45 PM
