Dealer required customized settings
Old 03-05-14, 04:29 PM
doodlebug
doodlebug's Avatar
Default Dealer required customized settings
Has anybody had the 3 blinks for lane change adjusted to 5 or 7 blinks by the dealer? Or better yet, is there a way that we can do it without the dealer? I know that GS owners (I don't know what year) are able to change theirs. And, I recall instructions to retrieve the navigation firmware version on our cars and was hoping someone knew how to change the number of blinks.
Old 03-05-14, 04:37 PM
specONE
specONE's Avatar
Dealer only adjusting LPS or getting a copy of the OBD cable and use TIS Techstream Lite to do it.
https://www.clublexus.com/forums/is-...-question.html
Old 03-05-14, 05:00 PM
onepointon
onepointon's Avatar
Do this, it may sound confusing and take a few times. Reread and try again if it fails.
1.) Ignition off, doors closed
2.) Hold the wiper switch in the full up position. (this is the wiper off position)
3.) While holding the wiper switch in the full up position, turn the IG on. (two presses of the start/stop switch)
4.) Hold wiper switch in the full up position for 5 seconds
5.) Move the wiper switch down one "click" or "notch", hold for 5 seconds
6.) Move the wiper switch back to the full up position, hold for 5 seconds
7.) Move the wiper switch down one "click" or "notch". hold for 5 seconds (same position as step 5)
8.) Move the wiper switch back to the rest position (neutral)
If this was done correctly, the right turn signal will flash once.
To adjust how many flashes you want, you change the intermittent wiper speed switch. P1 starts with the speed switch all the way at the bottom, P4 will be the top speed. This is found on the wiper stalk.
P1: 3 blinks
P2: 5 blinks
P3: 7 blinks
P4: Function turned off
Set the intermittent wiper speed to the desired setting.
Use the Turn Signal stalk and push down like you want to activate the left turn signal, the flashers should activate
If the turn signal blinks once, you change it to the "3 flashes" setting
If the turn signal blinks twice, you changed it to the "5 flashes" setting
If the turn signal blinks three times, you changed it to the "7 flashes" setting
If the turn signal blinks four times, you turned the function off.
Once this is done, cycle the ignition switch off, and back on, and it should be changed.
I know this is confusing. I have done it to a few customer cars, and mine. The first one took a bit to understand, and I have given you the cliff notes. The repair manual is confusing as hell.
Good luck. If there are problems I will try to walk you through it.
BTW: regards to the above comment, this function cannot be changed through the Tech Stream. The method I posted is the only way it can be changed.
Old 03-05-14, 05:41 PM
specONE
specONE's Avatar
Originally Posted by onepointon
BTW: regards to the above comment, this function cannot be changed through the Tech Stream. The method I posted it the only way it can be changed.
thank you for pointing this out.
I read too fast and thought he was talking about other personalize settings.
thank you onepointon, I will try this myself as well.
Old 03-05-14, 07:50 PM
Vairox
Vairox's Avatar
P1: 3 blinks
P2: 5 blinks
P3: 7 blinks
Worked awesome man, took a few tries and it got to 7 but wanted 5 so it took a few more tries but I got it thanks man!
Old 03-05-14, 08:41 PM
breezytint
breezytint's Avatar
Thanks "onepointon"
works just as described.....
Old 03-05-14, 10:05 PM
dojoman
dojoman's Avatar
Really tedious way to change something that should've been a simple setting in the car lighting setting.
Old 03-05-14, 10:47 PM
sc00b
sc00b's Avatar
cool mod. i changed mine to 5
thanks for the instructions!
took me a few tries but got it down!
Old 03-06-14, 04:08 AM
onepointon
onepointon's Avatar
Nice! Glad it worked for everyone.
Old 03-06-14, 04:58 AM
doodlebug
doodlebug's Avatar
Thanks onepointon.
Old 03-06-14, 06:33 AM
BBoyM3
BBoyM3's Avatar
Thanks for the procedure!
Old 03-06-14, 04:45 PM
Bass Mech
Bass Mech's Avatar
i was going to change mine, but i try to avoid using my turn signals! as soon as you use one on the highway some clown comes up to cut you off! so i prefer the stealth and surprise approach, i signal as i am already making the lane change. therefor 3 blinks is plenty.
Old 03-06-14, 06:18 PM
waxy
waxy's Avatar
Kudos to those who use blinkers when driving.
I had the dealer do mine, they gave me a loaner for it.
Also had them check my Nav issue, problem still remains.
I thought I was the only one.
Old 03-06-14, 06:22 PM
vbx
vbx's Avatar
When I had my 3IS, Lexus of Westminster said "they couldn't change it to 5 blinks". This option was only available on the GS or something like that.
And that was from 2 different locations. The first time they said no was when I picked up the car. The 2nd time was when I brought it in for the software update.
Old 03-06-14, 07:15 PM
beeRandon
beeRandon's Avatar
Does this work for the is350 fsport 2014? Can't seem to get mine to work. Maybe i'm stupid :P
Quick Reply: Dealer required customized settings
