how to replace the rear reflection light!! help
I try to change my rear reflection light on my 3is. i couldn't take it off to replace it.. any idea that i can take that off
To remove you must take off the rear bumper entirely. The reflector is bolted down from the inside and there's no way you can reach that small bolt from the bottom. The rear bumper is fairly easy to remove. There are 1 bolt on each side in the inner fender wall. Once you remove those 2, go to the bottom of the car and remove all the clips that held the bumper to the bottom cover. Then there are one bolt on each side of the taillight that bolted the bumper as well.
Simply pull the bumper outwards then you will be able to remove the reflectors bolts inside.
msekanha
10-29-20 12:48 PM
