DCT custom steering wheel
#32
I can't answer for this car specifically, but whenever you change a steering wheel be sure to disconnect the battery and pump the brakes several times to drain any residual charge - don't want to risk anything setting the airbags off.
#33
I haven't finished the video, i just kind of forgot about it. But I can upload what i have for sure tonight. Also, it's really easy to remove the stock wheel. Disconnect the battery (one terminal on the left), then there will be 3 clips on the airbag when you remove the plastic cover bits, you need to unhook those with a flat head or something, they'll look like some pins, you just simply move those to the side and they release the airbag, you'll see it snap out. Then the whole airbag will just slide out. Take a picture of all the wiring so you know what goes where, then unhook everything. If you need help with the process when you do it, email me at theshaddix@gmail.com and I'll reply asap.
#34
Wow. Thank you for your fast respond. I will try to remove again tomorrow. I will email you if I have any question while try to remove it. Again thanks a lot for your help.
#37
New inventory - Carbon sport Lexus IS XE30 steering wheel with red stitching
We now have this red stitching carbon steering wheel back to stock
red stitching wheel goes fast, contact us to order yours
sales@dctms.com
Sample picture of steering wheel installed
sales@dctms.com
rmsimmonsj
09-26-16 11:32 AM
