Can you program the key to roll UP the windows
I know that when you hold down unlock on the keys the windows go down
i was wondering if there is a way to program or roll up the windows with the keys ...?
According to this, you can have it programmed by the dealer to roll up with the KEY, but not the FOB.
See Item 21:
http://www.lexus.com/pdf/service/14I...i-customer.pdf
See Item 21:
On the 2IS, you can roll down the windows with the FOB UNLOCK by pressing and holding, (in Europe you can roll them up too), but to roll them back up I've pressed and held the little black button on the door handle and it rolls up the windows/moonroof. Despite my access to these models, I'm burried in paperwork right now but if a 3IS owner wants to try and hold the little "LOCK" indentation on the door handle and see if it does the same as the button when the windows are down, see if it rolls them up.
https://www.clublexus.com/forums/gs-...t-the-key.html
the buttons dont work on the handle..
but if you put the key in the door and hold in the lock position the windows and the sunroof will go up and close.
problem solved
problem solved
I had this feature on my VW and loved it. Yet, I ask and researched. Yes, you can roll down with the fob. NO, you cant roll up. Yes, the key will close everything. Yet, the key is a PITA to remove from the fob.
On f-sport models we are limited to black or roja red interior with silver carbon trim.
And we don't get AWD or the 350 model
magne
05-21-15 10:22 AM
