How Much to fix
The pursuit of F
Was thinking the same thing. No sure if the bumper cover is bent out of shape near the trunk lining or if it's the 2 scratches. Pic is too close up and the reflections (or what appear to be reflections) make it difficult to determine what the damage is.
If it's just the two scratches, ballpark a couple hundred dollars and not worth going through the insurance.
If the bumper cover need replacement, about 1K (I got mine replaced on my 2 IS when someone lightly rear ended me).
The pursuit of F
^^^Based on the updated info, definitely less than $500. At most it's a little bondo, sanding, primer, and repainting of the section to look like new. Go to a body shop for a quote. Carstar is nationwide in both US and Canada I've used them through my insurance and they do a good job. Good luck.
Its a small ding. If ure not too OCD about your car, let it be as is. Once there are tons of dings n scratches, then replace it altogether. Just in case someone do it again and you already paid $$$ to fix this one. Just my $0.02
Probably $900-$1000. The cover looks a little distorted above the exhaust pipe and at the top edge. If it's creased, they will have to remove the bumper cover and use heat to shrink / massage it back into shape. They will then repaint the entire cover which is expensive because Lexus uses a three stage paint system. But when it's done you won't even know it happened.
I had nearly the same thing happen to one of my previous rides and it was about $1250 because I needed a new exhaust tip too.
joyner1977
01-26-14 11:43 PM
TwinTurbo9
RX - 3rd Gen (2010-2015)
08-10-11 07:35 PM
