PROBLEM: Phone keeps connecting and disconnecting!
Old 04-25-15, 12:05 PM
  #31
jkonquer
jkonquer's Avatar
this happens to both iphone 4s and iphone 6, i just plug and use bluetooth to stream music.
Old 04-30-15, 09:02 AM
  #32
ShakMan
ShakMan's Avatar
Originally Posted by ShakMan
This is absolutely correct. I have been using my Galaxy S4 with ZERO issues with my Lexus ES300h for the past 12 months. I was able to play audio, use ALL the apps and get txt messages with no issue.
Last night mine got upgraded to Android 5.1. Since this morning I have started experiencing Bluetooth disconnects. It does not stay connected for more than 1 minute. I have tried this in my garage with the vehicle parked. Deleted my Bluetooth and paired it again. No luck.
I am going to delete the bluetooth profile from my cell phone and test again. Will let you know
Got this working (somewhat). Had to delete my profile from phone and car 2 times before this worked. The trick is to click 'do not ask again' at the contacts/SMS sync options. However, I have lost my SMS notification capabilities. This is the direct result of Android upgrade to 5.1 for my Galaxy S4. I would NOT recommend this update if you had everything currently working.
Old 05-02-15, 07:57 AM
  #33
Aeromotive
Aeromotive's Avatar
This is not true. I had the problem with my S2 with Android 4.xxx
As I said in an earlier post, the problem is with the car not being able to handle more than a given number of SMS in its memory. The fix is simple, unpair and disable SMS sync.
rogerh00
NX - 1st Gen (2015-2021)
09-24-18 04:56 AM
ultran00b8
03-27-14 01:24 PM
GregsLexus
RX - 3rd Gen (2010-2015)
15
02-21-12 12:43 PM
jamiesmith
HS 250h Model (2010-2012)
05-25-10 01:58 PM
garyr
09-07-07 10:08 AM
Quick Reply: PROBLEM: Phone keeps connecting and disconnecting!
