Quck tire ? for 20" wheels
Old 04-15-14, 12:30 PM
Kybball#1
Kybball#1's Avatar
Default Quck tire ? for 20" wheels
You wheel/tire guru's feel free to chime in. Of course I want the most tire i can get for a better ride but dont want the rear to rub. Rubs bad with my 10.5 in the rear now here are the specs:
20 x 9 +35
20 x 10 +40
What sz front and rear tires should I run ? Im not gonna dump but I am on coils am would like to lower rear some more..
Was thinking:
225/30/20
255/30/20
or
235/30/20
255/30/20
or
225/35/20
255/35/20
what you guys think?
Old 04-15-14, 12:58 PM
RayG
RayG's Avatar
20 x 9 +35
20 x 10 +40
Was thinking:
225/30/20
255/30/20
or
235/30/20
255/30/20
or
225/35/20
255/35/20
What wheel and tire specs are you running now ? lowered ? if so on what ?
Old 04-15-14, 01:25 PM
Kybball#1
Kybball#1's Avatar
Yea, i stated in the begining of the post,
Wheel Specs:
20 x 9 +35
20 x 10 +40
Im on RSR Sport i coils....
Old 04-15-14, 02:41 PM
Mr_VFS1
Mr_VFS1's Avatar
I would suggest 225/30/20 and 255/30/20. I am running that currently on my wheels. It is a stretched tire setup so depending on your wheel, part of it might stick out. It might rub a little in the rear depending on how low you go but you could always do a minor fender roll if that is the case.
Old 04-16-14, 06:42 AM
Kybball#1
Kybball#1's Avatar
Anyone else with thoughts, i need to order them today???
Old 04-16-14, 07:01 AM
Mr_VFS1
Mr_VFS1's Avatar
What wheels are you running? How low are you?
Old 04-16-14, 07:55 AM
Kybball#1
Kybball#1's Avatar
20 x 9 in front
20 x 10 in rear
Old 04-16-14, 08:04 AM
juvi22003
juvi22003's Avatar
If i was to pick one of your specs i would go with 225/30/20 / 255/30/20 but if it was my car it would be 225 30 front and 245 30 rear....
Old 04-16-14, 08:08 AM
Mr_VFS1
Mr_VFS1's Avatar
I would have to agree with Juvi on this one. I am running 20x9/20x10.5 and 225/30/20,255/30/20 is perfect for my setup. I am only going to be on springs so there is still some space but it should be fine for you.
Old 04-16-14, 08:52 AM
Kybball#1
Kybball#1's Avatar
I just dont like the stretched tire look, guess ima have to deal with it if i want to go a lil lower, Personally i think that 10.5 im currently rumming is to big for the 3is..
Old 04-16-14, 11:00 AM
jaznraz
jaznraz's Avatar
Your switch from a 10.5+45 wheel to a 10+40 wheel will only gain you 1mm of clearance between the outer edge of the rim (and tire) to the fender (not much). It's not about the width, it's about the offset. Plug in the numbers here to see for yourself: http://www.1010tires.com/Tools/Wheel...ulator#Results
Did you see this thread? It should provide the answers you are looking for: https://www.clublexus.com/forums/is-...recommend.html
I don't have personal experience with 20's, only 19's.
https://www.clublexus.com/forums/is-...wered-3is.html
https://www.clublexus.com/forums/sus...s-of-info.html
Honestly, If you don't like stretched tires, I would suggest that you get 19's.
Old 04-16-14, 11:37 AM
Kybball#1
Kybball#1's Avatar
Thanks for all the info, ima go with
235/30/20
255/30/20
for now, i switch rims alot, maybe ill go 19" with my next set, i just think 20s look much better on these cars...
Old 04-16-14, 11:55 AM
larry13
larry13's Avatar
Thanks for all the info, ima go with 235/30/20 255/30/20 for now, i switch rims alot, maybe ill go 19" with my next set, i just think 20s look much better on these cars...
yep you change alot. so 19" in about 3 weeks :-) right in time for your joez exhaust
yangaroni
GS - 1st Gen (1993-1997)
03-08-12 04:26 PM
jc11
11-04-10 12:52 PM
jwin
07-26-08 03:46 AM
radicalrev
VIP Style
04-20-08 05:45 PM
02Ku
Wheels, Tires & Brakes Forum
04-06-06 08:42 AM
Quick Reply: Quck tire ? for 20" wheels
