Turn off freeway exit information on Nav
Hey guys,
Is it possible to turn off the freeway exit info on the nav? This is the info that shows up when you are in a long stretch and it shows POIs in between your current location and the exit that you will take. I do not like that it takes up half of the screen to display info I do not need.
I couldn't enter address on my Nav today. The address icon was greyed out and is couldn't select it. Then it came back on for few seconds before it was greyed out again.
Anyone else is experiencing this issue?
You can't enter an address manually when the car is in motion.
I checked...I'm actually on Map Only Mode and the Freeway Exit List Mode is greyed out...My nav is full screen but when turn by turn directions come up it takes up half of the screen which I am fine with, but when I'm in a long stretch to my exit on the freeway I get these info of all the exits in between and it takes up half of the screen...The weird thing is the Intersection Mode is also greyed out and these two infos are showing up in my Map Only Mode...somehow these modes are merged into the Map Only Mode?
