Full white LED interior less than $9 shipped review
https://www.clublexus.com/forums/gs-...light-led.html
Try that link. I heard it's the same for the 3is.
You can access the passenger side without taking the panel off.
It took me about 10 mins per each footwell light to get them off. Use a towel or if you have any rubber strips, that helps with grip. Just pull and wiggle them out. Just don't squeeze too hard because they are made of glass.
If you don't want to mess with unscrewing things and taking things apart, all you need is a little patience and wiggling.
Get a piece of blue painters tape (other tapes may work too if you don't have painters tape). Wrap the sticky side around the glass part of the bulb that's stuck in the socket, but leave a short length of tape hanging down. Pull down on the hanging tape, the bulb should come out easily.
This is how I got the footwell bulb out:
I don't know what the policy is for posting links to ebay. I'm too lazy to read it.
Here it is: http://www.ebay.com/itm/301014756087...84.m1497.l2649
It was given to me by another user. Highly recommend it! I bought the Xenon White version, the brightness is perfect for me. Not too bright. Just a bit more than OEM but with pure LED white.
