Paddle Shift Manual Won't Work?
Old 02-15-23, 07:18 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
No. While I'm driving, car up to temp, I put the car into manual mode and it will not shift with either the paddles or the shifter ****. The cluster shows M and whatever gear it is currently in, but will not respond to shifting. No feedback whatsoever. No check engine light, horn and cruise both work.
Old 02-15-23, 07:58 PM
arentz07
drives cars
arentz07's Avatar
Received 3,790 Likes on 1,924 Posts
Wow. Have you tried disconnecting the battery for a while and then trying again? Seems like this could be an electronics issue.
If it's still under warranty, if I were you, I'd be at the dealership as soon as I could.
Old 02-15-23, 08:05 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
Yeah I had the battery off overnight and no go on the warranty. It's a 14'. Just bought it and got hosed by the "dealership" I bought it from. Trans was just the tip of the iceberg with undisclosed issues.
arentz07 (02-15-23)
Old 02-15-23, 08:30 PM
sunamer
sunamer's Avatar
wow, sorry to hear that.
Old 02-15-23, 08:34 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
Appreciate it. It was my own fault, I trusted they were going to be honest. Gone are the days. Appreciate your time though. My issue has to be something simple. Always is. 5k scan tool gave the tranny a clean bill of health so I guess checking fuses and relays is next. 🤷‍♂️
Old 02-16-23, 06:57 AM
sunamer
sunamer's Avatar
Does the tranny shift normally in auto mode?
Does it shift from the "gear shift" lever itself?
I am wondering if the tranny got reflashed with some "tuned" firmware.
Old 02-16-23, 01:14 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
It shifts perfect in drive. Won't shift w ****. I reset the trans ECU yesterday.
Old 02-16-23, 04:12 PM
sunamer
sunamer's Avatar
If I recall correctly, someone here (a long time ago - maybe even @Sasnuke ) mentioned that paddle shifters and the gear shift **** produce the same event in the system regardless of where it is originated from - paddle click or gear shift **** movement (in M). Since both are not working, the issue is clearly not in some switch failing. For some reason something is precluding those gear shift events from being generated... or "heard".
Do you have any devices plugged into OBD2 port? some custom wiring maybe?
Old 02-16-23, 04:14 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
No sir. Car is bone stock. The two plugs are plugged into the shifter assembly as they should be also.
Old 02-16-23, 04:19 PM
sunamer
sunamer's Avatar
I know that some people rewire those because the gear lever shifts backwards from the ideal "downshift forward, upshift - backward" pattern. I am curious if this might have been done on your car.
Also, what happens if you leave it in D while driving and attempt to shift the gear (either by the paddles or by gear shift ****)?
Old 02-16-23, 04:23 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
Absolutely nothing. The paddles and the shifter are completely dead. Almost like they're not hooked up. No codes came up for the tranny either. I appreciate the help regardless.
Old 02-16-23, 04:36 PM
sunamer
sunamer's Avatar
very old thread but might give you some ideas
moderator edit: no cross-forum linking, thank you.
Old 02-16-23, 04:41 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
Awesome thank you! I have something to at least start with now. I appreciate the help very very much. Everything works as it should just not the eshift. And occasionally the sunroof. 🙄. Def got hosed from the dealer. Thanks again!
Old 02-18-23, 10:03 AM
nitroracer
nitroracer's Avatar
It was a couple of posts down. He was not even moving when he was expecting the paddle shifters to shift through gears. You need to be driving at 15 - 20 mph or over to shift out of 1st gear shifting up.
And he thought it was a real manual.
Nimo
GS F (2016-present)
03-15-18 05:22 AM
430keeper
09-12-14 02:17 PM
spotxc
03-30-14 02:17 PM
Jimt9
08-06-13 07:35 PM
jgreezy
04-15-10 06:50 PM
Quick Reply: Paddle Shift Manual Won't Work?
