Aftermarket Shift Knobs
to put in moat aftermarket *****, you push the boot portion that's holding it up to the kbob down, then unscrew the stick one. then you gotta remove panels and take off the part with the navigation controls. push the boot inside out and cut the little ziptie that holds the old plastic clip and boot together, then put your new kbob on, or ziptie the new adapter to it. i put in a new ziptie in the same way as it was before but onto my new kbob you can follow the beatsonic radio removal guides as a reference for how to take that section apart.
nikogio38
06-25-15 11:00 AM
Wunko
12-03-12 06:46 PM
