or you could go 10mm wider around for more grip. I went with 235/40/18 and 265/35/18. PSS are a lot more square than stock tire sizes so it was bigger than I expected but no rubbing
not all tires are sized the exact way its calculated, you can get two 225/40/18 and they would be different sized. Stocks seem to be on the small side. Some tires are more square on the sidewall than others.
